Removing stock GT spoiler
Can anyone pinpoint me to a tutorial for removing the stock spoiler? I'm looking to remove it tomorrow to get my GT500 spoiler on there. I've heard of using fishing line to "saw" through the adhesive after removing the four bolts. Is there any particular way to do that or does simply sawing through it work fine? I wouldn't want to cut through the clearcoat on accident. What type of fishing line? Thanks.
Same process as removing the other emblems, you can use floss or fishing line. I wrapped either end around some pencils,made it easier to hold. I'd use 20 or 25lb fishing line.
https://mustangforums.com/forum/2005...-question.html
https://mustangforums.com/forum/2005...e-removal.html
Don't forget to take off the 4 nuts under the trunk lid
Oh, you're in for a LOT of fun no doubt . Two bolts accessible under the decklid then you have to wrestle with the double adhesive. I didn't use any fishwire etc. just pulled up gently on the spoiler until it came loose. The adhesive will separate, no doubt anyway.
If I had to do it again, they sell some adhesive dissolver at the local parts store. I rubbed and rubbed and rubbed for 30 minutes getting all of the adhesive off.
I was too scared to mess up the cars finish... and put another coat of wax on once I was done.
Don't worry about messing up the clearcoat.. it take some REALLY abrasive action to do that. You will STRIP the wax off though and just put another coat of wax on when done, but NOT on the area that you adhere the new spoiler to. That area must be WAX FREE for best adhesion.
i got through it in less than 1/2 an hour by blowdrying a bit for heat, then using some minty floss to help "saw" through the adhesive. the floss worked alot better than i anticipated too. i don't know if you'd wanna goo gone the extra adhesive left from the stock spoiler or not, seeing as you're putting on a new one that will cover it anyway.
Don't rock the spoiler back and forth as it becomes loser.
It will dent the metal at the edges.
The fishing line can't get between the 2 studs of the spoiler, you'll need a putty knife to finish the job up. So you might as well ditch the fishing line idea and use the putty knife from the get go. It will take about 2 minutes.
Just mask around both bases with two inch tape so you don't scratch the paint while the knife sticks out at the other side.
The Cobra spoiler eventually will hide scratches but if you go back to stock for some reasons, it will show them then.
