Need help with removing stripped screws from hood
Hey, guys. As you probably know, I removed my factory hood scoop on Sunday to finish removing my racing stripes from my hood. The scoop itself was very diffictul to get off. This is mainly because each of these two stripped screws are being held in place on top of the hood by a spacer and on bottom by a nut. There were four metal screws total before I removed the scoop, with the remainder being made of plastic. Me and my boyfriend tried unscrewing the nuts but the three components spin together. I tried holding the screw with pliers as he used a wrench to try and unbolt the nuts, but that didn't work. I went to the dealership yesterday to get some replacement plastic retainers for the scoop and explained the problem. The guy in the parts department came out to my car with a little tool to grip the spacer while I tried to unscrew the bolt, and that didn't work either. So he suggested a power drill to drill out the screw from the top of the hood. So we tried that today and it didn't work. My bf tried making a little hole at the top of the screw but since all that did was tear the paint off the screw. Obviously we don't want to mess up the hood so he didn't try hammering the screw out. It's getting extremely frustrating. Here are some pictures of the screws that are stuck in the hood:
Has anyone had this happen to them? Can anyone tell me how to resolve this problem? I'm in dire need of your help so please let me know. Thanks.
someone with a steady hand and a die grinder air tool to grind the head off so it will push down through the hole, put lots of tape around it so if it does run off it will not hit any paint. sucks they are stuck like that.
It looks like the size of the hole would allow the screw to just fall through if that metal spacer wasn't there... I would try a dremel with a metal cutting blade and just slice the metal spacer & screw right through the center and pull the metal space out from the side and let the rest of the screw fall through.
I would try holding the protruding bolt under the hood, on the tip of it, with vise grips. Put your wrench on the nut and loosen it as far as you can until the vise grip interferes....
Then go to the top of the hood, should be enough slack to push the bolt upward. Grab that with the vise grips, and finish unthreading.....
Good luck.
Good luck.
Good luck.
Good luck.
Use a dremel. I remember saying your car would look good with the setup you are going for yesterday Victoria but I can't believe it's this much trouble now.... sad face. The warranty guy is a bit of an ******* for not completly fixing the problem as it's clearly a defect and the car is warantied for that.
Alright. Well luckily my bf's brother was here and he was able to take a look at it. He had a special type of pliers he used to grip the metal square while my bf slowly twisted at the screw for awhile... basically what myself and the guy from the Ford parts store tried, only this time it worked. So the hood scoop is back on now, but unfortunately it's not on there as tight as it was. It needs the four metal screws that it had, and only two are on there now. They told me yesterday at the dealership that I didn't need the other two once I got them off, and that the plastic retainers they gave me would suffice. They did not. So it looks like I'll need to try another dealership to track them down and possibly even replacement retainers. We tried AutoZone and a couple other places but came up dry. We also tightened the GT500 spoiler since it needed a couple more washers to get the adhesive all the way down. It's not quite all the way down, but it's much better. I'll wash the car in the morning and take a few pictures. Thanks to everyone for your help over these last few days... it is greatly appreciated.
09-16-2015 07:53 PM
