driveshaft with stock height....
Do i need to adjust the pinion angle if my car is gonna stay at stock height? also if i do how hard is it to adjust with adjustable control arms? i plan on getting the spydershaft? any other recommendations on which driveshaft to get?
Not sure what you are asking here.
If you are keeping stock ride height, why the adjustable LCAs?
Here is the driveshaft angle checking procedure.
there are several good choices, i don't
recommend any one in particular....i can
however say, i'm very happy with my
dynotech 3.5".
to see how i set up the pinion angle:
http://www.users.qwest.net/~cookpagi.../miscmods.html
dynotech 3.5".
If you have 20's on the car you might need an adj panhard bar to adj the center of the axle but other then that your fine as is to get the DS!
+1 if you're staying stock height, you don't need to adjust the pinion angle. The following article by Crazy Al does a good job in describing the effect of the adjustable LCAs of the pinion angles.
http://www.cherod.com/mustang/HowTo/LCA%20_adj.htm
Galactic
04-29-2019 02:56 PM
Luke9222
10-22-2015 11:55 PM
