Sponsored by:
Sponsored by:
Nose lift for Mustangs?
Old 01-28-2009, 09:14 PM
DarkFireGT
DarkFireGT's Avatar
Unfortunately, I don't think you can have it both ways, without getting some kind of custom control set made for a coil-over set-up. The only ones that come with remote activation would be bags/hydrolics, which will negatively affect the handling.
I guess you just have to decide. Do you want to look better going down the road, or handle better on the course? I mean, your car looks great, already. You won't have to pump it up to 4x4 to go over things. Just stock height. When your done with your drive, drop it back down.
DarkFireGT is offline
Old 01-28-2009, 10:41 PM
lucki96gt
lucki96gt's Avatar
This is a shot in the dark but do you adjust the coil-overs under the hood where the strut mounts are? If so, why don't you try to find a shop that can build you a set up for coil-overs that would turn the bolt for you at the flick of a switch? Kinda like a nitrous bottle opener but stronger. Like a dual(or quad for the rears) remote air wrench with an air compressor. Now that would be kick ***! Then you can have excellent handling and the great street manners.
Pull up to a steep drive and hit the switch and it make that pit-crew changing the tires noise! LOL!
lucki96gt is offline
Old 01-28-2009, 11:23 PM
Texotic
Texotic's Avatar
If you go with Coil-Overs from Tein, they have a module called the EDFC that you can purchase and have installed that allows you to remotely adjust the coilovers from the drivers seat. However, this only adjust damping to my knowledge. To change the ride height with coilovers, you have to rotate the threaded spring seats and I can't think of a design that would be able to turn the spring seat on the car without creating clearance problems. So coilovers aren't going to be your best choice. I don't have anything to offer other than reiterating that bags are probably your only option.
Texotic is offline
Old 01-28-2009, 11:27 PM
ChiDiddy
ChiDiddy's Avatar
or they have this black foam specifically for preventing scrapes where you stick it under the bumper therefore no more scrapes to the paint.
ChiDiddy is offline
Old 01-29-2009, 01:59 AM
07musclemustang
07musclemustang's Avatar
oh just suck it up and bag it all around.. Its sexy and rides like your on air.
As everyone else says its "bad" for performance i would have to dissagree, I dont think its the BEST performance set up but it is a definate imporvement over stock
07musclemustang is offline
Old 01-29-2009, 02:19 AM
usmcpony
usmcpony's Avatar
I do like the kit you showed me but I would hate to buy it and find out there is a kit. I am going to do more research and if all else fails I will get that kit. Also why did you get rid of Eleanor instead of your read one. It just seams you had more money in it but I could be wrong.
usmcpony is offline
Old 01-29-2009, 02:21 AM
usmcpony
usmcpony's Avatar
That was exactly what I was thinking. Well not the pit crew noise lol.
usmcpony is offline
usmcpony
usmcpony's Avatar
Where can I find it???? Thats a good idea.
usmcpony is offline
Old 01-29-2009, 02:22 AM
usmcpony
usmcpony's Avatar
I might have to! I agree it does look sexy.
usmcpony is offline
Old 01-29-2009, 06:13 AM
05 Mustang
05 Mustang's Avatar
sounds like some sort of air system is what you're looking for
05 Mustang is offline
Quick Reply: Nose lift for Mustangs?
