strong vibration at idle..
this has been going on for sometime and it would only happen occasionally so I never really thought too much of it.. but being as it has been cold recently, it seemed to be happening more often than usual and I discovered it only happens when I turn on my defrosters. After turning them on, there will be a strong vibration at idle but once I step on the gas it'll go away and come back once idle again.. happens for a short period of time but is this anything to be worried about?
i've got around 50k.. and yes i let it warm up, i haven't ever really noticed it during cold starts, it usually happens later on when the car has been warmed up for sometime. and i actually run on 89.
Check for clearance to exhaust hangers at midpipe, & heat shields. There is a new tsb that has to do with removing the hangers cause they cause noise in the center stack & shifter area. The hanger may touch the transmission crossmember & cause vibes at different times. Exhaust systems grow as they heat up.
10-01-2015 05:13 PM
treesloth
09-28-2015 07:03 AM
