Quick question about a GT/CS bumper from ford
+1! Its the very same bumper, don't let them BS you into paying the 500 bucks! Tell them how you want it painted, i.e. GT/CS stile.
So either i read/did something wrong or the guys at ford are retarded. They told me that the gt/cs accessory bumper was just the bottom part and that it would go over my gt bumper. So they order the $500 bumper instead of the $350 accessory cs bumper. Did i get ripped of? Im thinking that if they are wrong, its because they saw the pic where the bottom is all black and thought it must be just that part.
This is from him a Ford parts dealer who works at a Ford dealership as their part manager:
""Ok Here is the Lowdown on the Other Parts. Ford Really Has A Mess on there Hands With Service Replacement Parts and Genuine Ford Accessory Parts. Most Dealers are Unaware of the Accessory Parts so you Usually Get Quoted for the Service Replacement parts Vs the Accessory Parts. The Service Parts are More than the Accessory Parts And you get Less! The Service Parts are Just a Bare Cover Where the Accessory Kits Have Extra Goodies. If you Have a Gt You Will be Good to Go With the Accessory Kits but if You Have A V6 you Will Need the Additional Gt Pieces your V6 will need to get to GT Bumper Specs! I as A Rule do Not Often Post Parts Prices or Part Numbers Because they Change Regularly. In This Case I will Post FORDS Suggested Retail in Order to Give you the Best Deal when Purchasing these Parts Locally!
Ford Suggested Retail, Part Number, Description
$472.88 7r3z17d957aa GT/CS & SHELBY GT Service Bare FRONT Bumper.
$399.00 6R3Z-6320049-AA GT/CS & SHELBY GT Accessory Kit Front
Bumper.
$518.27 7r3z17k835aaptm GT/CS & Shelby Gt Service Bare Rear Bumper.
$355.00 6R3Z-6320049-BA GT/CS & Shelby Gt Accessory Rear Bumper
$ 596.00 7r3z17k835baptm GT-500 Rear Service Bumper.
No Quote Kit for true 500 Rear Bumper. The Only Difference between the CS and 500 Bumper is a Lot of Money and the Rear Diffuser. On A CS or Shelby Gt the Lower Center Diffuser As Viewed From Directly Behind the Center lower Section Only is Matte Black on a GT-500 The Lower Section is Black all the way around to Match the Matte Black rocker Panels. Other than That the Rear Covers are Identical! Do the Math and Make your Choice! I hope this Clears up the Bumper Cover Mystery!""
no sirs, you have it all wrong. I used to own a GT/CS and the GT500 bumper is different than the CS bumper. The texturing on the GT500 bumper diffuser is different than the GT/CS bumper when both are unpainted. This means painting a GT500 bumper will cost more than the GT/CS and be harder to get right.
Will the sides be textured or smooth?
Here is some pic's of that very bumper (with the textured sides) the texture is so fine that the paint pretty much fills it in as you can see. Everything below that lower line you see on the bumper is textured.
