Cervinis Side exhaust
I have the magnaflow system and the setup is a little different than DarkFire's. Mine does not wrap around the gas tank and there is actually only one muffler. I also have the MAC L/T's with an O/R Prochamber....and yes, having side exhaust will make you very aware of the road. Scrapping happens maybe once a week but its never bad and only hits the small pipe that goes from the muffler to the tips. I was under the car for 22 hrs installing the L/T's and didnt notice any significant scratches.
I made it and sorry it took so long and like darkfire stated it is a CAT back system so any header /CAT combo can be used.
Here is the pic of mine....... Allstar just PM me next time for faster results!!!!!!
Doesn't help much but...
from the side before the tip was installed
All mandrel bent turns and flows quite well IMO...if I lost HP it was not much....
My tips are not lined up perfectly but they do fit where they should..
Drivers side
passengers side
Mind you many changes to appearance except for the side exhaust!.... I love it but you can and will have clearances problems.....esp if lowered....no regrets on my end though and I live in Michigan....the pothole capital!!!!
Vegas roads aren't that bad...but the driveways can definitely suck! If I'm not careful I'll scrape at even low speeds on most entrances and exits - in the desert the driveways are heavily dipped to allow for flash flood waters to flow easier to reservoirs. Unfortunately for me the road builders out here didn't consider my car before they started building their stupid "fast draining" roadways! Scumbags!!!
