3rd brake light removal
I had the guys at the body shop at work smoke my taillamps on Friday. Tomorrow they are going to do the marker lamps and 3rd brake lamp. Does the 3rd brake lamp just pop right out from the back??
Replacing high-mount brake lamp bulbs
1. Make sure the headlamp switch is in the OFF position and then open the trunk.
2. Inside trunk, pull the trim panel straight off of the underside of the trunk lid.
3. Locate the lighting assembly and push the release tab to access the bulb socket.
4. Carefully pull the bulb straight out of socket.
Install the new bulb in reverse order.
bond007
08-26-2015 11:36 PM
