help removing mustang grill
I used a long thin flathead screwdriver for the lil tab. Bent that up and used another screwdriver to push the pc from the grill threw the slot. The ones on the bottom are easy just pull up and pull the grill and it will pop out. Do the sides first its easier that way. I dont know if i explained it that clearly but i hope that helped.
I guess what has me confused, Is that I thought all the tabs were plastic, and here it is saying to bend the tabs (as if they were metal)????
There are like a rubber plastic i bent mine real far and they just bounce back to their normal location. There are 2 on the left and right and about 5 or 6 on the bottom just dont get frustrated! It just makes it take longer. Have fun and put some pics up when your done
Just make sure when you line your CDC grill up you double check the spacing a couple times and make sure its even on both sides... one of my little clips on the cdc was bent so maybe I had to measure a couple times extra...
