Any advice or tips on roush hoodscoop install?
My hood scoop is currently in the body shop getting painted. It's going to be installed Friday evening, does anyone have any tips or advice I should give to the mechanic about installing it. It didn't come with a template so its going to be a little tuff but i think he will do a great job. I can't wait...so if you got tips/advice, please share..thanks
UPDATED ----- Pic's at the bottom!!!
no template....hmmmmm....interesting...i am in the process of replacing my stripes so i had to remove my roush scoop to get the stripes off....the car is still without the scoop on it....its sitting outside....let me go get some measurements for you....brb.....
I would call Roush and get a template just to be safe. They once gave me a free replacement hardware kit for there trak pack grille so I would see no problem in getting a template. Unless the installer has say another Roush car to measure off of I could only see them eyeballing a good location for it while making sure it's even.
Here ya go!
http://store.roushperformance.com/im...pdf/401345.pdf
That'll be One hundred BILLION DOLLARS!
thanks man, and do you think they have the template online somewhere to print out?
that install procedure doesnt give drill points....
here is what i got for you...use your best judgement...
(make sure you measure your hood from left to right and use a grease pencil to draw your centerpoint line on the hood from front to rear so you can get an accurate location for your center hole)
Overall view of holes
This is the center hole measured from the windshield edge of the hood towards the front
Here is the passenger side washer hole measure from the windshield edge of the hood
Here is the drivers side washer hole measured from the drivers side fender of the hood
Here is a measurement of the front 2 passenger side scoop corner holes measured from the windshield edge of the hood
Here are the front scoop corner holes (drivers side) measured from the fender side of the hood
use a grease pencil to mark the holes on the hood before doing anything...step back to visually check to make sure everything is symetrical...make sure the mechanic uses a center punch to mark hole locations before drilling to prevent the drill bit from walking on the hood...
i know this might be a bit confusing but i hope it helps...
i would go with trying to get a template from roush if you could....
