Mustang Sequential Tail Lights best place to buy?
#21
#24
#25
WebElectrics =s Tawain produced on cheap phonelic PC boards
and CDC are made right here in the USA on quality glass epoxy PC boards.
I have seen the WebElectrics, the Meter4It kit and the CDC Dynamite
Sticks. The WebElectrics are poorly made with wide tolerance electronic
componentry. This varys the timing cycle widely. Not good with sequentials.
And the use of 85 degree C capacitors instead of 105 degree C
capacitors as is needed in a mobile application means a short life span.
The meter4it kit is OK but not waterproof and not plug-n-play.
Soldering is required for proper installation. The best are the CDC Dynamite
Sticks. They interface with the S197s SJB perfectly and have the soft
start for longer bulb life. They are also available as a true plug-n-play
installation.
I bought mine straight from Web Electrics...
http://www.webbelectricproducts.com/
https://mustangforums.com/forum/2005...ns-wanted.html
#26
Brenspeed has two sequential listings. One is CDC dynamite sticks, which are $156; the other is just Dynamite sticks, which are $100. Is there a differnence, or are they the same?
#28
I called brenspeed before i got mine last week. They said there really is no differnce. He said that the one is just branded with the CDC, the other one does not. I got the 100 dollar one on wed and put it in. One car wash and some snow and rain, still no problems.
#29
has to be run up to the SJB to have the brake lights come on without
chase when only the brakes are applied. They only chase when the
turn signal or the hazzard lights are used.
Diode Dynamics
28
05-26-2022 12:02 PM
