Having trouble with a rattle/vibration in baffle of exhaust.
yeah buy new mufflers... non flowmasters..
its a relatively common problem.. that being said ive heard of it 3 times
if hes gonna cut open the muff and reweld. DO THEM ALL
and then hopefully it should never happen again.
Im supprised a reputable company has issues with crap welds. i thought it would have been robotic
anyways if you love em and its cheaper fix it if not upgrade to mid muffs
I have heard that this is a common problem with Flowmasters. I haven't had that problem yet and I have had mine for over two years. If you just bought them, they are still under warranty. Have them replace under the warranty.
For what it's worth, I thought I had the same thing, until I took off my stock H-pipe. The catalyst had been blown out and was rattling around in the mufflers. I suggest you have them take the H-pipe off first, and take a quick look inside. If you catch the same problem I had, you might save yourself from blowing your engine.
Yeah, but you're missing my point. It might not be one of the baffles rattling around in there, it might be a chunk of catalyst that traveled downstream and is caught in your muffler. If that's the case, you need to get your cat(s) replaced ASAP!
