Side Door Scoop Question
mine are out getting painted now,here is a link http://www.fordgenuineaccessory.com/...ategory=Scoops
Make sure you look at a factory installed one before you install your's. I used the template and it didn't appear that the holes were drilled correctly because it was set back a little from the door edge. I worked it to align with the door edge but then saw later it was intended to be offset. Looks good either way actually.
I would also recommend you find a car or photos of one that is the same color as yours before making the investment. I picked up a set on fleabay real cheap, but after seeing them on an Alloy GT500 ragtop, I opted to not go forward with the install as they just did not flow well with my color. I think they look great on some of the lighter color cars (like white or silver), but IMO look out of place on darker cars.
I think there is a set for sale right now in the classifieds.
