Best Street Gears
If I was going to skip any gears it would only be 3rd on the way up. I'd be unlikely to downshift into second for driving through a corner that I did not have to come to a full stop for. Starting from a dead stop in 2nd even with 4.10's puts quite a bit of extra wear on your clutch because whether you realize it or not you do have to slip it a bit more.
Even though I don't have 4.10's in my '08 I have been through all of these situations and more in another car of similar weight where the overall gearing matched what's going on here so closely that you'd never notice any differences. It is a little higher-strung on the highway than necessary, but around town I've never found the different shift point speeds to have been a problem. The more you keep yourself aware of how hard you're making the engine work, the less a little "extra" shifting will bother you.
Norm
For sake of comparison.
Stock 235/55/R17. 27.18"
3.55 gears
1st gear tops out, 6200RPM, @ 41.78MPH
2nd gear tops out, 6200RPM, @ 70.60MPH
3rd gear tops out, 6200RPM, @ 106.97MPH
4th gear tops out, 6200RPM, @ 141.21MPH
4.10 gears
1st gear tops out, 6200RPM, @ 36.17MPH
2nd gear tops out, 6200RPM, @ 61.13MPH
3rd gear tops out, 6200RPM, @ 92.62MPH
4th gear tops out, 6200RPM, @ 122.26MPH
3.55 gears
4.10 gears
mungodrums
09-28-2015 10:54 PM
nmra1965
Other Professional Racing
09-26-2015 10:46 AM
mungodrums
Suspension
09-24-2015 10:12 PM
