Cam covers leads oil in my SC intake..
No, it forces it from the positive (passenger side) to the negative (driver/intake side) up into the intake.
Look at your engine. there is a hose on the drivers side cam cover that connects to the intake right behind the throttle body. that's the negative side where the oil is pushed from the crankcase up into the intake.
the connection on the CAI is the positive side, where fresh air (in the intake tract past the cai filter) is pushed throught the crankcase to eliminate stale gases.
sorry dont have any pics w/ the breathers on.
but the breathers are from K&N, they are crankcase breathers, the passenger side is 3/8 inch, the drivers side is 5/8, you can order from summit or jegs, or might be able to get a local autoparts place. and the oil cap breather i got from Central Florida Motorsports
http://mustang.c-f-m.com/index.asp?P...odID=2160&HS=1
IMO the breathers look nicer, and easier to install, the only drawback is wiping the blowby off the passenger side, so i will put in a small separator soon and keep the rest of the breathers.
I also wanted to just disconnect my PCV and add breathers. they look sooo nice and clean! but everything I heard is that pcv is essential for negative crankcase pressure and the same problem you're having would occur with leakage.
that sounds like it makes sense. i'm looking into a smaller catch can, bc i didn't like how the moroso one looked in the engine area. now that i think about it, when i had the pcv connected i did see more blowby out the driver side, but w/ the breathers i see it out the passenger side. i am definately putting the catch can back on, but will use a smaller better looking one that i can tuck away and be less noticeable.
I'd leave the driver-side and/or positive side connected and add the catch-can on the passenger (negative) side. That seems to be what all these 700+hp guys are doing (and all the high boost imports I've seen).
IMO, you would want the negative crankcase pressure just not the oil residue.
n/a it wont effect much more than just having things clogged up, FI and its more a octane thing and detonation.
My system is different than most, my system is not tied into the factory intake at all, it draws air thru the crankcase from the suction of the turbo,filters the oil out thru the catch can.since installing the catch can i have not had a drop of oil make it past, im using #12 stainless steel line with a morroso catch can,works great.
my catch can is in the top right,by the brake booster. i have one hose that connects just before the turbo in the filter inlet, for constant suction,the other hose is then connected to the driver valve cover,and on the passenger valve cover i just have a filter. so the turbos constant suction draws freash air thru the passenger side cover.I do have a problem,like i knew i would, of oil coming out of the filter on the passenger side. when the motor is being pushed hard, there just is not enough suction, so its forcing oil out of the breather filter,ill have to add another line to the passenger side and put some sort of catch on it or route it to the catch can as well.
Here is a quick shot of my layout:
The can is in the bottom right of the first pic next to the coolant overflow tank. The line runs from the driver's side valve cover under the coolant tank to the can then back from the can to the intake.
