Biggest tire on stock 17??
Max recommended is a 255/50/17.
If you want to run a taller tire a 275/50/17 will fit but it is 28" tall. Problem is for street tires is that there arent any performance tires in that size.
If you want max traction you can get a 275/50/17 M&H DR which is ok for the street but you have to be very careful in the rain.
RECOMMENDED on a stock 17 x 8 Bullitt wheel is actually 235 but you can probably go 255's safely. The recommended on the 18 x 8.5 is 255, FWIW.
Check the tire manufacturer's tire specs for his recommended wheel size for any given tire.
M3hunter
09-05-2015 03:42 PM
