What else do i need if im lowering the rear .75"?
So if I got the roush rear lowering springs, what else would i need with them? Do i need a new adjustable panhard bar or new adj lca's?? It's not a big drop so I was just wondering, please let me know. Thanks Also if anyone has pictures of just a .75" drop in the rear that would be great!
Jersey - I would guess that with only a 3/4 inch drop you are not going to see a need to further alter the suspension components. If you want to make sure you can always measure the rear axle vs. centerline to determine how far it has moved.
For larger drops it was recommended by the forum's suspension guru's to utilize and Adj. PH Bar, Adj. LCA's, and an adjustable UCA. I also replaced my shocks/struts with Tokico D-Spec's to allow me to adjust the rebound with the stiffer springs.
HTH
~Matty
HTH
~Matty
When I did my roush stage 2 kit I also did the adj panhard bar. I called up roush and they said it was not needed but I did it anyway.
It will cost around $175 or so, but since you are under there - you might as well
