Sponsored by:
Sponsored by:
tire senors ?
Old 03-16-2009, 03:16 PM
deekum1627
deekum1627's Avatar
Default tire senors ?
my senors is on and it says tire moniter pressure fault but the tires are fine so whats up with that im going to clear it with my tuner and see what happens
deekum1627 is offline
Old 03-16-2009, 03:27 PM
5SPD07GT
Official Site Sponsor
5SPD07GT's Avatar
did you get the tire sensors put on your new wheels?
5SPD07GT is offline
Old 03-16-2009, 03:33 PM
Smooth_J
Smooth_J's Avatar
You need to program the TPMS system. Pickup the following form the dealer 8C2Z-1A203-A and then following the below instructions:
Turn the ignition switch to the OFF position, then press and release the brake pedal.
Cycle the ignition switch from the OFF position to the RUN position 3 times, ending in the RUN position.
Press and release the brake pedal.
Turn the ignition switch to the OFF position.
Turn the ignition switch from the OFF position to the RUN position 3 times, ending in the RUN position.
The horn will sound once and the TPMS indicator will flash if the training mode has been entered successfully. If equipped, the message center will display TRAIN LF TIRE.
NOTE: It may take up to 6 seconds to activate a tire pressure sensor. During this time, the Tire Pressure Monitor Activation Tool must remain in place 180 degrees from the valve stem.
Place the Tire Pressure Monitor Activation Tool on the LF tire sidewall opposite (180 degrees) from the valve stem. Press and release the test button on the Tire Pressure Monitor Activation Tool. The horn will sound briefly to indicate that the tire pressure sensor has been recognized by the SJB.
Within 2 minutes of the horn sounding, place the Tire Pressure Monitor Activation Tool on the RF tire sidewall opposite (180 degrees) from the valve stem and press and release the test button to train the RF tire pressure sensor.
NOTE: Do not wait more than 2 minutes between training each sensor or the SJB will time out and the entire procedure must be repeated.
Repeat Step 7 for the RR and LR tires.
The procedure is completed after the last tire has been trained. When the training procedure is complete, the message center (if equipped) will display TIRE TRAINING COMPLETE.
For vehicles not equipped with a message center, successful completion of the training procedure will be verified by turning the ignition switch to the OFF position without the horn sounding. If the horn sounds twice when the switch is turned to the OFF position, the training procedure was not successful.
Smooth_J is offline
Old 03-16-2009, 03:34 PM
Nuke
Nuke's Avatar
Assuming you do still HAVE the sensors, you may need to have them recalibrated. My Ford dealership had to recal mine after they swapped the sensors to my new wheels. It only took a minute or so.
Nuke is offline
Old 03-16-2009, 03:48 PM
5SPD07GT
5SPD07GT's Avatar
i just put the Roush wheels on my car and to the best of my knowledge they dont have the sensors at all. I havent gotten any codes or dash lights though so i'm starting to wonder. I'm going to be putting new tires on in a few weeks, guess i'll find out then
5SPD07GT is offline
Old 03-16-2009, 03:58 PM
deekum1627
deekum1627's Avatar
when i got my new rims they came with the senors and the light came on but then it went away for a month and now its back on and stayed on
jwog666
12-27-2021 08:09 PM
CS2007
06-25-2019 09:45 PM
KingRando
10-02-2015 08:06 AM
marc954
09-29-2015 11:18 AM
nmra1965
Other Professional Racing
09-26-2015 10:46 AM
Quick Reply: tire senors ?
