ready to buy, help deciding
so i got the green light from the woman to go ahead and buy a set of drilled/slotted rotors and brake pads since my car is starting to squeel and i thought i heard a slight grind while coming home from the gym right now.
now i have to decide between the two kits i was looking at
1) baer decelarotors drilled/slotted rotors are about 300 bucks for all four rotors only, plus i need to buy the brake pads
2) irotors kit 300 bucks for the drilled/slotted rotors plus the pads
i'm thinking of going with the irotors kit since it comes with the pads but was wondering which you guys would go with. i'll be making the purchase after work at 6am.
here are the links
here are the links
baer
http://rpidesigns.com/shop/item.asp?itemid=1481&catid=
irotor
http://www.irotors.com/storefrontpro...52&i=233278093
here are the links
baer
irotor
I thought u could get roto pros for like $200 and they are zinc coated and they look exactly the same as the ones you posted? I have not seen a thread on them for awhile but before I know guys were buying them like nuts, think taco has a write up on them.
