Sponsored by:
Sponsored by:
New Tank and still BROKE!!!
Old 06-17-2005, 07:20 AM
Boozshey
Boozshey's Avatar
Default New Tank and still BROKE!!!
Well I finally got my new gas tank installed. I was so excited to fill the tank up. So I start filling it up and what do you know!!! 35 Liters and then CLICK CLICK CLICK CLICK.... Just a little over a half a tank. Before it was 1/4 tank and then Click. Maybe if they change it 3 more times I will get the entire 1/1 fill... haha...
Anyways, had to vent.
Boozshey is offline
Old 06-17-2005, 04:14 PM
lostsoul
lostsoul's Avatar
Default RE: New Tank and still BROKE!!!
yup.. mine too and I heard of others.. its a little better.. but still the same on some pumps.. I lost an antenna and got my front plate bent to sheeeet.. so I'm not going back inless its a big issue
lostsoul is offline
Old 06-17-2005, 04:24 PM
Professor Wizard
MF Moderator
Professor Wizard's Avatar
I just picked up my car last night (June 16th, 05") ... ran the hell out of it driving home from the dealer.
Decided to refill at my regular local gas station. With the hose put in "normal" it would only click. So I turned the hose nozzle counter clockwize 1/4 turn (so it aligned parallel to the ground.) and it work fine even under FULL pull pressure on the handle.
I guess they don't quite have the gas tank filler tube "perfect" yet. However - looking under the car the thing looks pretty puny to me.
Professor Wizard is offline
Old 06-17-2005, 05:47 PM
05SonicBlue
05SonicBlue's Avatar
oh man. i just had mine replaced wednesday, but haven't put gas in it yet to test it out.
05SonicBlue is offline
Old 06-17-2005, 05:57 PM
delurker
delurker's Avatar
Looks like a garden hose from the filler neck to the tank. Fuel nozzle upside down works every time for me.
delurker is offline
Old 06-18-2005, 12:55 AM
Orion_240
Orion_240's Avatar
It's working for me at the 3 o'clock position.
The TSB says it was more of a vapor venting problem.
The new fuel tanks are supposed to have a "revised internal venting system".
Anyone have a before and after photo or specs?
Orion_240 is offline
Old 06-18-2005, 02:58 AM
Scaught
Scaught's Avatar
I went on vacation for a week and when I came home and tried to fill my tank it only filled to over barely 1/2. But today I filled it again and if filled up no problem. My car was built May 5th, must already have the tank "fix" or some such. Sucks not to be able to fill a tank all the way.
Scaught is offline
4cylinderplus2
10-09-2020 07:45 PM
b8checker
10-08-2015 12:55 PM
b8checker
09-30-2015 07:11 AM
mrappe
09-26-2015 10:16 AM
stangin1996gt
09-21-2015 11:01 AM
Quick Reply: New Tank and still BROKE!!!
