ok would this be a good solution?
Ok i have done some thinking, i had a post about my raspy loud exhaust wtih bassani o/r x, i was wondering if anyone has done this or if it would work, since my bassani x is a 6 peice system i could easily cut my stock h pipe behind the cats and clamp in the bassani x. it wouldnt exatcly be high flow cats but it would be a cheap solution considering u dont get much hp from high flow cats anyways on these cars. I have also had some replies saying they are running o/r h pipe and it sounds alot better i could cut my stock h pipe out and clamp it to my bassani catless manifold pipes? just wondering if anyone has tried any of these?
both pipes
i use a o/r h as the mid, but i also use a shop made x, the o/r h in my opinion sounds better than the o/r x, but that all comes with taste. as long as you don't live in a emissions test state, cut the cats it will flow better, plus you get the sweet smell of no cats
mungodrums
10-07-2015 04:01 AM
