Last edit by: IB Advertising
Browse all: Ford Mustang GT Powertrain Guides
- Ford Mustang GT 2005-2014: How to Replace Radiator
Step by step instructions for do-it-yourself repairs.
Anybody change their coolant/antifreeze yet..????
I am in the same boat.. only 4,500 miles on my 06.. but coolant doesn't really care about mileage.. it WILL go bad no matter what.. trust me..!!! I have seen it.. it may check OK.. but it will still deteriorate inside.. believe it or not.. lol
The Ford service schedule calls for changing based on time or mileage, whichever comes first.
For the factory fill, 6 years or 100,000 miles.
For subsequent fills, every 3 years or every 50,000 miles.
I got you both beat...I only got 2400 on my 07 GT...
If it's just a bit low then top it off according to the manual's instructions. You don't want to mix coolant types so if it is the Ford factory fill then you need to get the right stuff and not mix it up with Prestone. Also, if your levels keep getting lower then you need to watch for leaks.
Just mix 50/50 coolant/distilled water in a gallon jug and top it off. I flushed and filled mine when I installed the blower. I used the Ford stuff, but will be going to prestone next time. I don't like the gold coolant.
