MOTOR MOUNT QUESTION ??
Is there a way to tell if your mounts have more play in them than when new? Are they supposed to last the life of the car?
I was thinking about them to help improve shifting as it should stiffen up the drivetrain.
From what I've seen posted, the standard Prothane mounts actually raise the engine close to 1/4", so the 1/2" lowering mounts really only lower the engine about 1/4".
Something rubbing on the hood liner?... Might want to check the hood liner itself for sag. I have an '05 and the paint on the ribbed portion of my factory intake cover is rubbed off. This is caused by a sagging hood liner.
I have removed the intake cover for paint repairs and I am planning to drop the hood liner, spray trim adhesive on the back side of the hood and back side of the hood liner. I'll place a pile of pillows on the top of the engine, lower the hood down on the pillows and let the weight of the hood compress the hood liner up against the backside of the hood. Hope this will resolve my sagging hood liner problem.
Man after reading some of the links about mounts I realize there is a lot more to this. I guess I'll be doing a little more research on this. The one from Moss $$ I think I would probable go w/ the lowering type because I have a "Strange Shock Tower Sway Bar" that rubs the hood liner.
Im glad someones awake, I dont know what i was thinking Your absolutey right it aint going to lower my strut brace. Daaaahhhhh me. You dislike them that much? What was it that made you say Ive had enough? and so you put the stock ones back on.
Luke9222
10-22-2015 11:55 PM
