HELP with tire sensors
can anyone tell me if theres a fuse for the tpms.i have changed rims twice and my car has not detected that the rims dont have sensors.i know people are gonna ask me why i want the light to turn on,well i dont but i want everything working how is suppost to.
OK
Do you have sensors in there rims you changed twice?
Did you reuse your original TPMS sensors and transfer
them to the new wheel(s) you changed twice?
If they are new untrained sensors, they need to be trained.
http://iihs.net/fsm/?dir=71&viewfile...20Training.pdf
http://iihs.net/fsm/?dir=68&viewfile...g%20System.pdf
http://iihs.net/fsm/?dir=70&viewfile...)%20Sensor.pdf
http://iihs.net/fsm/?dir=70&viewfile...d%20Cradle.pdf
http://iihs.net/fsm/?dir=66&viewfile=SPECIFICATIONS.pdf
none of the rims have sensors.the thing is this my two front rims are the stock ones that came with the car,but when i change to the rims to go to the track(no sensors in them)the light wont come on.the other day i went to a car show and i put a set of 20s from my older car, againg no sensors in them and the light came on and turned off after a few seconds, i havent seen the warning light since then.i was gessing theres a fuse or something.now this is my second 2008 mustang gt and my other one will turn the warning light after a couple of minutes after driving with the rims for the track.
http://iihs.net/fsm/?dir=40&viewfile...r%20System.pdf
The book shows you little.
Where are your rims with the sensors in them when you start the stang
with the non-sensor installed track tires? Within radio range of the SJB?
One guy has his 4 stock tires layed out in his garage right next where they
would be if they were actually bolted up and when he starts his stang, the
SJB reads the tires next the stang and does not set off the TPMS warning.
Its a complicated system as the requested reading above might imply.
mungodrums
09-28-2015 10:54 PM
TfcCDR
09-14-2015 12:08 PM
