Lower and upper control arms?
#23
Getting back on track now...
So would it be overkill or bad to have an adjustable UCA with adjustable LCA's? I'm asking this because I like Spohn products and since I already have their adj. panhard bar, I might as well go with their adj. LCA's(poly/spherical) and their adj. UCA. They don't make a solid UCA. I know they have solid LCA's but I'd rather have the ability to easily adjust the pinion angle via adj. LCA's.
#24
IMO also having a adjustable UCA is not necessary. They both provide the same adjustment. Does Spohn make an adjustable UCA with poly/poly ends? If so you should go with that rather than a poly/rod combo, to reduce noise.
adjustable, arm, arms, body, bushings, control, ford, fox, gt, mustang, mustangutube, rear, relocation, replace, work
