how much hp can a 05-09 mustang gt engine handle
Old 05-03-2009, 10:26 PM
  #31
war machine 115
ok...gotcha...thanks
war machine 115 is offline
Old 05-04-2009, 08:13 AM
  #32
blackcrow
my ten cents... I've been building engines for over ten years now, and like you guys said, its a combination of several factors... hands down, 450~480whp its a good safe bet. However, hooking it up with slicks adds up, a lot of torque down low at the rev range (turbo & pos dis blowers) adds up, a poor tune, bad gas, high rpm (over 7K) adds up, and garanteed, you will blow it up. There is a time and a place for everything...
Personally, I am currently running a Procharger, its got good whp but relatively low torque (515whp/436tq). I smoked the clutch a while ago, currently using a Spec stage 3+.
My recommendations if venturing beyong...:
use good gas or additive (Lucas) when going racing
don't rev beyond 6500 rpm with stock long block
make sure you have a good tune
be on the rich side always
use a wideband
don't get happy with the timming
...did I mention having a good tune????
I you can't comply, don't do it or start building the piggy bank.
So far, [email protected], 1.6-60' on ET Streets, it's up to you!
blackcrow is offline
Old 11-05-2018, 12:34 AM
  #33
Jojo Mahon
Default HP
hi my name is Jo and I have a stock 2007 Mustang 5 speed and I am doing engine swap with a 5.4 supper charge will the trans be able to handle that and the clutch?
Jojo Mahon is offline
Old 11-05-2018, 02:50 AM
  #34
Dino Dino Bambino
Dino Dino Bambino's Avatar
If you use all the power available on a frequent basis, especially if you run slicks, you'll eventually break either the clutch, tranny, or both. The TR3650 is rated to 390lbft and a supercharged 5.4 will make way more than that.
You could consider doing a TR6060 swap from a GT500 in addition to the engine. That tranny is rated to 600lbft.
Dino Dino Bambino is offline
Old 11-05-2018, 01:16 PM
  #35
Stkjock
Retired Mod
Stkjock's Avatar
your realize you'll need a new clutch set up as well.
As Dino suggested a TR6060 swap is a good idea
Stkjock is offline
squishbang
Suspension
11-02-2015 03:42 PM
krazykevin
08-18-2015 08:42 AM
01moostanggt
Suspension
08-13-2015 07:48 AM
05slpGT
The New S550 2015-2020 Mustang
08-12-2015 02:32 PM
daytooday
08-11-2015 09:22 AM
Quick Reply: how much hp can a 05-09 mustang gt engine handle
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
