steering vibration after header instal - Page 3 - MustangForums.com
Go Back  MustangForums.com > Ford Mustang Tech > 2005-2014 Mustangs
Reload this Page >
Old 04-30-2009, 07:11 PM
  #21
Linde
Originally Posted by MadMike1337 View Post
i feel mine is def steering cuz i feel a tapping when only making right turns. i noticed that it only taps the steering link when in gear making a right turn. when im not in gear when making a right turn there is no tapping. i thought that was odd when i figured that out today
I guess thats because your engine is not under load and therefore it is not moving much.
It was exactly like that on mine, in most senarious.
Try move the engine just a little to the passanger side. Its so easy, you could redo it back if you donīt get good results.
Linde is offline
Old 04-30-2009, 09:57 PM
  #22
MadMike1337
MadMike1337's Avatar
Originally Posted by jahudso2 View Post
My vibrations were never in the steering wheel, it just felt like it was coming from the front end and i assumed it was the steering shaft. I will let you know tomorrow if my rattling is gone. Mike, does the collector on the drivers side touch the side of the engine block where the header meets the midpipe?
i dont think my collectors touch the block. from looking in the engine i dont think so i may have to get under to get a better look. i have a pic of the collectors that i took that i can post but i dont know how to post pics. when u pushed the motor over did u have to lift it again and push or did u just loosen the nuts and push hard haha
MadMike1337 is offline
Old 04-30-2009, 10:01 PM
  #23
MadMike1337
im probably going to give it a shot this weekend since i have some time. did u have to lift and do it or did u just push hard after lossening the nuts
Old 05-01-2009, 02:50 AM
  #24
TPony
TPony's Avatar
NIce vid...
TPony is offline
Old 05-01-2009, 03:00 AM
  #25
Linde
No lifting, used an ironbar engine moved easy.
Linde is offline
Old 05-01-2009, 05:27 AM
  #26
jahudso2
Yeah the only way I noticed it was laying underneath the car. On my drivers side, it looks like where the mating flange is for the h-pipe connection is touching the side of the block. I don't know whether that is causing some of my rattles or not. I guess I could take a picture and send it to JBA.
jahudso2 is offline
Old 05-01-2009, 11:09 AM
  #27
157dB
Cut & Paste Expert
157dB's Avatar
Originally Posted by cbrstng08 View Post
NVH = Noise, Vibration, Heat
The motormounts will stiffen up the enging and keep it from rocking under throttle and also it will raise the engine a little as well, so they should solve your problem.
NVH
Noise
Vibration
HARSHNESS
157dB is offline
Old 05-01-2009, 12:43 PM
  #28
MadMike1337
here is a pic of the DS mine isnt touching block.
Old 05-03-2009, 06:56 PM
  #29
jahudso2
Ok well i took off my front wheels today and I found that the front swaybar endlink connection to the strut mount on the drivers side was very loose. I torqued this nut down and now I have no more knocking noises. I guess i never had any issues with the steering shaft after all...
jahudso2 is offline
Granatelli Sales
The New S550 2015-2020 Mustang
21
04-27-2017 02:33 PM
SSG Steggy
3.7L V6 Technical Discussions
11-05-2015 04:09 PM
raleigh05GTO
09-04-2015 08:09 AM
Luke9222
09-04-2015 07:46 AM
cbird1177711
09-02-2015 09:51 PM
Quick Reply: steering vibration after header instal
Featured Sponsors
