steering vibration after header instal
hey guys im back again. FINALLY i got my instal done that msot of you helped me out on as i ran into some walls. i installed JBA shorties and mangaflow x pipe. i absolutly love the new sound and the power. it is def noticable and i feel more thrown back in the seat.
however, i have a slight steering vibration from the DS header tapping on the shaft when making right turns. easy right turns, im scared to take a hard on haha. what are my options to resolve the issue. do i need the stiffer MM? i did do some research through the search option... what is NVH? It seems like these stiffen the engine from moving and allows for more of a power transfer to the ground? What are the cons of installing some stiffer ones? |
NVH = Noise, Vibration, Heat
The motormounts will stiffen up the enging and keep it from rocking under throttle and also it will raise the engine a little as well, so they should solve your problem. |
hey man glad to hear ya got it all in get a video up . . . and as stated above motor mounts should solve your problem . .
NVH is noise, vibration, and harshness. My steering shaft is rubbing my headers as well. Another member (Linde) just installed long tubes and his headers were rubbing. To solve his issue, he just loosened both the nuts on top of the motor mount studs and pushed the engine to the passenger side. Then he retightened the nuts and it no longer rubbed. I am going to try this trick this evening after my engine cools down. I'll keep you posted on how it works.
Originally Posted by jahudso2
(Post 6159153)
Originally Posted by 08SGT
(Post 6158693)
Not the first time I hear clearing issues with JBAs...
I had problems with them on Classic Mustang and the late ones are no exception I guess. Another trick is to put thick washers between the mount and the block... Not recommended with hi-torque engines though. |
haha here is the video. it could not be anymore perfect. needless to say my neighbor was not happy coming outside around midnight to find a suprise lol watch and see! turn the bass up!
http://www.youtube.com/watch?v=57yZjhdQYu8 |
Extra sensitive alarms are for morons anyways.
What does he have, a minivan? :D |
LMFAO i can't believe you set his car alarm off and you weren't even revving it. nice vid.
