Buying new mods....just need everyones input!!
From LethalPerformance.com
CHE severe duty Adj LCA w/poly bushings
CHE competition double Adj UCA w/ poly bushings- (LCA and UCA are cheaper than BMR, plus i think they have the same quality)
BMR chrome moly Adj panhard bar w/poly bushing
BMR front 1-3/8" sway bar
Tokico D Specs
BMR lowering springs
From Brothersperformance.com
complete gear installation kit w/ 3.73 gears
Mastershafters.com
3.5" Aluminum driveshaft-(any better recommendations for a good driveshaft)?
From Cruizinconcepts.com
Bullit Deep Dish chrome 18x8 front-18x10 rear
Nitto 555 255/40/18front 305/45/18
PLEASE GIVE ME EVERYONE'S INPUT..THANKS!!
Tokico D Specs
Mastershafters.com
Make sure you get a 3.5" drive shaft, the 4" will rub on a lowered car. This is something to not cheep out on like I did, mine still needs to be balanced...
I am using the CHE lowers w/ relocation bracket, so far so good.
Sway bars I noticed a nice difference, but the brand is up to you... I'm happy with the steeda one I purchased.
Hope this info can help. Good luck!
Thats a nice list of mods man...anyway, this is OT, but what exactly does the anti-roll bar kit do? Sometimes when im driving my car, for a split second it will feel like im losing control of it. Like i just hit a patch of oil or ice. Its fking scary.
EDIT: Do i need a bumpsteer kit?
Why are you buying a front sway bar when you just made your car handle worse than a decapitated duck with some of the other stuff?
Also you'd need about a thousand horsepower to make use of most of this setup, Is that what you're after?
It makes no sense to start lowering your car either as that will just be counterproductive, but I'll agree to go with the 3.5" shaft.
Hope that helps.
Hope that helps.
The anti roll bar keeps it from having body roll when you are turning corners or sharp curves on the highway. As far as the front sway bar i just thought if i was gonna do the rear suspension might as well do the front one. Yeah i think a set of pulleys sound good.
