SC and tire spin
05-03-2009, 11:41 AM
Quote:
Originally Posted by
BruceH
The more you drive it the less unintentional wheel spin will happen. Are you still on the stock tires?
This is my DD so it will be used virtually everyday. Nope, NT555.
05-03-2009, 11:46 AM
KDWs are a popular choice. Centri s/c's ftw!
05-03-2009, 12:05 PM
whtcanbrwnd04u
Hehe, you are right cause you don't have the low end TQ of a roots/ts/tvs :P
05-03-2009, 12:10 PM
Tire
Riptide
But a drag radial at some point becomes a requirement.
Agreed - Take a look at a Nitto drag radial (305/40-18) rear - I use these and have much better traction.
05-03-2009, 01:47 PM
OK, don't laugh....how many miles should a person average on drag radials if the car doesn't drag race or go around roasting tires?
05-03-2009, 01:52 PM
shanec
Depends on the DR. Nittos are known to last twice as long as MTs. But the MTs are alot better.
05-03-2009, 02:42 PM
So give me an idea here. Would I be looking at 12,000 mile pit stops for tires? 30,000?
05-03-2009, 02:43 PM
BTW, which wheel is speedo & odometer data based on?
05-03-2009, 03:17 PM
I took a look, and it looks like they don't have the size for the DR
255/45-18
So it looks like I have to go wider in the back if indeed I get something like this.
What is the widest I can put in the back with the following specs:
Back Spacing: 6.6" (167mm)
Offset: +40mm (1.6")
http://www.nittotire.com/functions/t...sp?tire=nt555r
05-03-2009, 03:24 PM
You could go with my plan....do nothing until the current set wears out. I'm sill sporting 17" stockers wrapped in P-Zero's.
When those wear out I'll get the size wheels & tires I really want.
