Saleen SuperShaker with CDC/Foose shaker hood?
I would like to know if anyone has paired the CDC Foose designed shaker hood with the Saleen SuperShaker. Saleen claims their supershaker works with hoods modified for the CDC shaker hood scoop so under that same line of reasoning shouldn't the CDC/Foose Stallion shaker hood also work with the Saleen SuperShaker?
http://www.classicdesignconcepts.com...t_detail&p=108
The CDC hood is horribly overpriced... Cervinis makes a hood that looks exactly the same, i wonder if that would work? When i decide to go the supershaker route (god thatll be atleast 3 years im sure), im gonn try the cervinis hood because i think thatll be the best look.
The Foose hood is made out of aluminum and fits like an OEM piece out of the box. The Cervinis hood is made out of fiberglass and, supposedly, requires quite a bit of body work to look good. Not to mention the aluminum is more rigid and lighter weight.
You're mistaking with Trufiber my friend.
That hood fits great but those required fender extensions, are a turn off for me and most people.
Fang performance were the first to come out with the 69/70 style but they might not be in business anymore.
The Foose hood is expensive mostly because it uses the OEM brace.
That means higher cost for Chip (Ford doesn't give anything away)
Chip puts then, his top skin on it and ship it to CDC.
BS!!
I'm sorry, you're right. That's my mistake, lol. But the Aluminum/fiberglass difference is still there.
