need a quick answer for stupid question
Fix-a-Flat is a temporary fix product and should only be used in emergencies such as when you're in the middle of Bumfu*k Egypt at 2 am. Both fix-a-flat and plugs will typically cause imbalance issues in addition to other problems stated in the previous posts.
+1 on taking it to a tire shop.
I've used a fix-a-flat before and they are a temporary solution. Other times, they don't work. The best thing to do is take it to a nearby garage or a tire shop. They should be able to find the problem and it shouldn't cost you much.
