Theories on why my shifting got clunky about the time i lowered the car?
my synchros should be fine, driving around 99.999999999% of the time i never have any synchro type issues, just 1 out of 20 times shifting hard to second, thats all
Adjustable UCA FTW.
A two piece driveshaft makes the lowereing effect on the pinion angle
just that much worse than a one piece driveshaft.
http://iihs.net/fsm/?dir=77&viewfile...easurement.pdf
Are you guys considering the 4 degree pinion angle the difference between the rear end and tranny angle...or 4 degrees off from perpindicular (sp).
I've seen it referenced both ways in the racing world.
Thanks for any clarification.
It doesn't really matter how you define pinion angle. What matters is the operating angles of your U-joints. Read the pdf file that 157db posted and follow the steps to figure out your operating angles. No more than 3 degrees continuous and no less than .5 degrees.
+1...For a normal street car with a few suspension mods 3.0-2.0 degress is about right. If you have a lot of mods then 2.0-1.5 degrees should work. Lastly, if you have a full race setup then 1.5-1.0 degrees works.
I did plenty of research before/after buying all of my parts and these were recommended degree ranges to adjust to.
I am running a 2.0 right now and no clunking .
Degrees from the tranny angle or output shaft. Both were zero on my car in my garage. You want to get your first angle (with a one-piece shaft) from the transmission/tranny output shaft. At 4 degrees my driveline is quiet and BARKS HARD on shifts. I've been trying to get that hard bark for a long time and 4 degrees worked.
ShaneB26154
35
03-04-2021 04:05 AM
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
