Sponsored by:
Sponsored by:
LONGER LUG BOLTS
Old 10-07-2009, 06:25 PM
Paulejr13
Banned
Paulejr13's Avatar
Default LONGER LUG BOLTS
HEY, HOW/WHERE DO I GET LONGER LUG BOLT FOR MY CAR. I SOLVED MY SPACER PROBLEM, BUT NOT THEY ARE TOO SHORT.
Paulejr13 is offline
Old 10-07-2009, 06:35 PM
Xeno
'Dr. X'
Xeno's Avatar
i'd try you local auto parts store first (unless you've already been there )
Xeno is offline
Old 10-07-2009, 06:57 PM
Tylus
Tylus's Avatar
we understand you have a problem
please stop using all caps though. that is the equivalent of an internet shout
http://www.mustangwheelspacers.com/i...WPROD&ProdID=7. These guys are real nice, and easy to work with
Tylus is offline
Old 10-07-2009, 09:30 PM
Paulejr13
Banned
Paulejr13's Avatar
my bad, im just going to return my spacers, and get the spacers that bolt to the stock hub and have new bolt studs on them like the h&r hub centric
Old 10-08-2009, 01:00 AM
Lethaldosage423
Lethaldosage423's Avatar
lolol i was thinking the same thing!
Lethaldosage423 is offline
Old 10-08-2009, 04:10 PM
157dB
Cut & Paste Expert
157dB's Avatar
Good idea.
Returning the rims and getting new ones with the correct offset
and not using spacers would be the ideal solution...
Spacers are nothing but trouble.
157dB is offline
Old 10-08-2009, 08:23 PM
Nuke
Nuke's Avatar
I was thinking longer studs to solve his problem would simply be a BIGGER problem.
Nuke is offline
Old 10-09-2009, 04:59 PM
Paulejr13
Banned
Paulejr13's Avatar
why is that??
Old 10-10-2009, 12:19 PM
157dB
Cut & Paste Expert
157dB's Avatar
Its called leverage.
Physics 101.
It works AGAINST you whenever
you lengthen the studs and insert
(sic) spacers.
The loads go out the window round
1 - 1 1/2" spacers.
157dB is offline
GimpyHSHS
19
12-19-2023 01:12 PM
baddog671
07-26-2016 01:20 PM
Thunderball
15
11-22-2015 11:49 PM
2poor4u2
09-26-2015 11:08 AM
maestro1024
09-21-2015 02:40 PM
Quick Reply: LONGER LUG BOLTS
