What the Hell? Brand new (900 miles) Mustang GT down 1/2 a quart?!?!
#21
I talked to the crew chief at Rockstar Makita Yoshimura Suzuki and he said they would NEVER break a motor in with synthetic oil. They gingerly break in on the dyno with conventional oil for two hours in intervals. We sponsor this team as we do many other factory race teams. This team has dozens of national championships under their belt, I am sure they know what they are taking about.
Take it for what its worth, if you think I am wrong, no worries, throw synthetic oil in anytime! Technology has come a long way in the 5 or six years since I built any motors, so maybe car motors are different now.
#22
These engines as far as I know it do not require a break in period. Unless you had your engine rebuilt from a shop engines now a a days come ready to go ..no break in requirement. It has been awhile since I have done a total rebuild myself and in the begining I was not sold on synthetic, for one the price, two I was old school and thought that regular oil and changes were just as good as synthetic. Sorry to rag on this thread, but its like the old saying "you can't teach an old dog new tricks" applies.
#23
My 2007 Owner's Guide says, "Do not add friction modifier compounds or special break-in oils during the first few thousand miles (kilometers) of operation, since these additives may prevent piston ring seating."
#26
Oil
Same here. There is no problem. Just enjoy your new ride.
#27
You aren't breaking in flat-tappet pushrod lifters any more, but most everything else that needs to get microscopically friendly with some other part is still there, and it'll still generate more heat fresh off the dealer's lot with a temp tag in the rear window than it will 5,000 miles later.
All of the engines that I've built were assembled with file-fit rings and with all clearances checked. You don't really know what the actual clearances inside that new 4.6 are. Most of the time it may not matter, but you don't know with absolute certainty that your individual engine is a "most of the time" unit or not.
Norm
#28
Just because I knew where to find this,
Norm
I'd go easy during the break-in period, especially if this car is going to be a "keeper". Ford is only listing what they consider to be minimum requirements with respect to warranty issues and no more. Don't forget that you're breaking in more than just the rings, bearings, and other engine parts. Transmission internals, differential gears, and even the clutch (if it's a manual) also need some sort of break-in period.
Break-in is an sort of final micro-polishing step between all the parts that move against other parts. Heat is generated, parts expand at different rates, and tiny bits of metal are worn off. It's best to minimize the heat (less likely to have a local hot-spot develop) and change the oil and filter early to get rid of the early debris. Varying the speed changes the way the oil splashes over everything, which also is in the interest of not letting hot spots develop. I should mention that oil is the main way that some parts are cooled, and is the only cooling available for others. This also means that the oil tends to run a bit hotter during break-in, which effectively shortens its life.
Probably the worst thing you could do would be to take a fresh engine and run it hard without waiting for it to (fully) warm up.
Norm
inyadreems
08-21-2015 09:10 AM
Displ8cement
Texas Regional Chapter
08-13-2015 12:37 PM
08-10-2015 02:02 PM
