Eibach Sport Springs + 20 inch wheels with low pro tires = HARD RIDE, need help
I lowered with the FRPP kit and the ride is pretty harsh with the 20". I have ordered the new Koni STR-T Shocks which should improve the ride considerably. These shocks are non-adjustable but are equivalent to the Koni Blue set to soft.
I'll let you know how the ride is with these shocks once I have them installed, but its gonna be a couple of weeks.
um correct me if I'm wrong but a 5% taller sidewall on a 20" rim will equate to only a inch overall taller tire right? Your saying with your sportlines you don't have an inch clearance? I only ask because I have my coilovers set at 1.75" lower in back with a 20X8.5 rim using a 245/35/20 toyo Z4 tire and I have like an inch of clearance. I to plan on going with a 40 series tire or a 255/35/20 when these wear out as the 35 is pretty harsh not to mention a little more sidewall on a stang looks great imo
NICE RIDE!
How close are your bumps to hitting on the back? you can just look through wheel and see them. When mine was first lowered, they were really close to hitting just sitting there, so i hit them all the time. You might be able to cut them some, and not have any scraping issues, but you should probably look into that before you go cutting them.
