Questions about VSS Color and VSS Pulse
Hi, Does anyone knows What's the VSS wire color and VSS Pulse for 05 'stang ?
I am going to put NAVI instead of Skipper 500.
I found couple post from "search",But still can't get clearly.
thanks
AK
thanks
AK
RE: Questions about VSS Color and VSS Pulse
ORIGINAL: JJSTANG
I found "Pin 14 is the Vehicle Speed" from the Shaker wiring diagram.
Has somebody checked this wire ? Is this the one ?
If you check you will see that Pin 14 doesn't exist on the Skipper units. That wiring diagram is for the Mach systems ( even though it says different ).
Open the hood and look at your PCM. Remove the cover from the top plug. Now locate the third wire on the left as you are looking at it. It will be a dark blue wire with yellow tracer.... there you have it myfriend. THATS youre output shaft sensor. No longer VSS because the PCM reads the OSS and makes up its own VSS inside of the PCM, so its electronic. You can read it with a scan tool and bring up the VSS pid.
ORIGINAL: hawgman
ORIGINAL: JJSTANG
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
