Help, WHeels don't fit
that are produced when the rotating cap rides up against the end of
the spindle. Metal shavings are not good for front bearings.
But all common sense tells me that the spindle and spindle nut goes through tapered bearings with the castle nut on the end squeezing it all together. So the spindle and spindle nut does not rotate as the wheel rotates which would cause rubbing and scraping?
Weird. Direct from american muscle
http://www.americanmuscle.com/simple...de-wheels.html
Originally Posted by American Muscle
Why can’t I put a 10 or 10.5” rim on the front of a Mustang?
The front end of a Mustang is set up in a way that will only allow a 9” rim to be used. The brakes, struts, A-arms etc. are located in or around the wheel well, and the wheel and tire are used to hold them in place. Because of their location, it is impossible to use a wider wheel without a significant amount of rubbing on either the inside or outside.
NorthAmericanTuning
11-09-2016 11:44 AM
JonnyBlazeGT
08-09-2015 10:19 AM
