Sponsored by:
Sponsored by:
Can't put gas in the tank on 08 GT?
Old 06-22-2009, 12:31 PM
jtstakelin
jtstakelin's Avatar
My 2006 escape did this. Filler neck had to be replaced. My 09 has done it once since I have had it. I think that the TSB was from 05. Try searching around for the TSB and take it to your dealer.
jtstakelin is offline
Old 06-22-2009, 01:36 PM
QtrMilePony
QtrMilePony's Avatar
I have an 06. I have had this problem several times, but it usually happens on the second half of the tank. I'm not sure if the gas is just having a hard time flowing over into the other half of the tank making it shut off the pump or what. The dealership here said there was a TSB for the 05, but it was fixed in the 06. (they had to redo the fuel tank) They are not sure what causes it. It never fails, it happens at the worst time. When it is raining, cold or I am in a big hurry. My husband has an 06 and it has never happened to him.
http://www.ford-trucks.com/tsb/tsb.p...y-2006/t-06313 this is for the 06. which the dealership told me there wasn't one, maybe this number will help them find something for you for the 09
QtrMilePony is offline
Old 06-22-2009, 02:04 PM
Bmr4life
Bmr4life's Avatar
My 05 has had this problem twice out of hundreds of fill ups.
Bmr4life is offline
Old 06-22-2009, 02:06 PM
Xeno
'Dr. X'
Xeno's Avatar
there is a tsb on this issue for 05-06 model years, but i suppose the same thing could happen to a later model year; it was common enough that i would have assumed the dealers had heard about this problem...
i have an 05 and had this problem too. went to the dealer, gave them the tsb number (they also questioned me how i knew about the tsbs too ... you'd think they'd know the internet is a vast and wonderful resource), they replaced the fuel tank, and now everything is working fine.
anyway, i attached the tsb for the 05 models, but the 'tsb 06-3-13' number hotdogn mentioned is an updated version of the 05 one. good luck
Xeno is offline
Old 06-22-2009, 02:12 PM
RobbieCopp
RobbieCopp's Avatar
I ave this happen on occasion. I just flip the pump upside down ad it wor2ks perfectly. When my neighbor had his 05 it did it too, but ford fixed it for him.
RobbieCopp is offline
Old 06-22-2009, 02:19 PM
Derf00
Gentleman's Relish
Derf00's Avatar
Originally Posted by CandyRedGT
Suddenly several weeks ago my 08 GT started acting like it was full when i tried to fill the tank! I originally thought the gas pump nozzle was messed up!! Nope!! Then i thought maybe a vent line got pinched when my engine mounts and blower were installed..Nope. Brenspeed said Ford has a TSB out on a filler neck/hose issue. Two dealers told me today that they have NO idea what i'm talking about??? I have to dribble a penney-nickel at a time!! Took 15 minutes for 8 gallons of gas! Anyone have this problem? Do you have a TSB ## or remidy...etc??? Thanks alot,Joe
This isn't an issue that comes up out of nowhere all of a sudden. Meaning if it didn't do it from the get-go, it's not going to. The tsb is for 05 to mid/late 06 models. Dealerships should be able to verify if your car is already using the revised part numbers listed in the TSB. Beyond that it could be the Vapor Lines running from the filler neck to the tank.
Derf00 is offline
Old 06-22-2009, 02:20 PM
RobbieCopp
RobbieCopp's Avatar
Old 06-22-2009, 03:59 PM
07 Stang
07 Stang's Avatar
Sometimes it happens to me, so I just turn the pump handle 45° to the left and not pump the gas so fast.
07 Stang is offline
Old 06-22-2009, 04:02 PM
pascal
S197 Section Modder-ator
pascal's Avatar
And where have you been girl?
Been a long while...
pascal is offline
Old 06-22-2009, 04:05 PM
o0xerog0o
o0xerog0o's Avatar
I've never had it happen on my 09 GT yet, but at work we have new diesel Dodge Sprinter trucks, and the one I drive has that issue... I've been able to find the sweet spot by putting it all the way in, and slowly pulling it out until I can go full pressure on it. I'll have to try to upside down pump next time.
o0xerog0o is offline
Quick Reply: Can't put gas in the tank on 08 GT?
