How do I remove the passenger side aluminum dash bezel?
How do I remove the passenger side aluminum dash bezel? The part on the right side of the two horizontal dash panels that cover the air bag.
I know there are two clips that hold the right side, but how do I pop the left side of the piece off?
My car is in the shop for engine problems, but I wanted to know how to do this when I get it back.
I have a rattle coming from this piece, I am going to pad it. I've taken it to the dealer twice with no luck so I figured I'll give it a shot.
you have to pull the two horizontal pieces with the airbag out. there is one bolt behind the glove compartment and then you just pull it out, there are alot of clips holding it in. then you will see two screws holding on the piece that you want to get out.
I think I have this problem. Could you be more specific as how to pull the vent out before I got and destroy mine haha
He's trying to remove the whole panel, not just the vent. You have to remove the airbag to expose the two bolts on the right side of the vent panel.
I tried a few ways to make it fit more snugly, but the only one that worked and stayed fixed, was to spray some insulation foam into the tight gap between the collar and the vent tube. It expanded and filled the gap. Careful where you spray it though. The vent still needs room to spin around in there.
Or it may just be your dash panel after all. But at least you'll have tried the easy fix first.
Luke9222
10-22-2015 11:55 PM
