Axle-Back Install
Axle-Back Install
Quick question??? Putting GTAs on 09 GTCS...got the first on centered and bloted, but for the life of me could not get the nipple all the way down to the "stopping point" on the muffler...if you drew a line straight across the muffler opening, the nipple is inside of that, call it flush with the top of the opening, but not all the way down...I'll work on pics, but how important is it to get it all the way???
1. I loosened the midpipe clamp and pushed with all my mite, to no avail.
2. The one side I did do (sounds nice compared to the other side = stock!!) I did not check for leaks with my hand...I will tonight...
3. FOR GOD'S SAKE if you are doing this install, listen to TacoBill and everyone else and invest in a ratcheting 13mm...I initially didn't, so my install was paused for a trip to sears
Yeah ratcheting wrenches have saved my *** on more than one occasion. Got mine with the pivoting head, too. Awesome.
I've taken mufflers off and put them on my car about a dozen times in the past 72 hours, and all I can say is that it depends on how much of the muffler pipe is into the over-axle pipe. If you have a *reasonable* amount of one pipe in the other, as long as it's clamped tight enough, it shouldn't cause any problems. That nipple wasn't completely against the stop point on my buddy's mufflers, and he had no problems. His were installed by a shop.
Another thing you could do is take the hangers off, hold the muffler in place, loosen the muffler clamp, and push in. You're guaranteed to get to the stop point. If the mufflers then don't hang well after you tighten the hangers, you can always take everything off, use a heat gun to heat up the prongs on the muffler and bend them gently until they're raised/lowered to a degree that will offer you the best fitment.
I've already had to heat and bend both hanging prongs on my passenger side muffler and will have to do so on the driver's side. It's an inexact science with one-piece mufflers...
*edit* Holy crap, it's TacoBill! Thanks for helping me (albeit indirectly) with 90% of my mods so far!
Please get some pics up! I am anxious to see how the install goes. I will be looking to order these in the future. Whats the easiest way to put them on, put the car on jackstands or just jack up one side at a time?
If I get to bending my exhaust hangers tonight, I will take some pictures of my install process.
I'll get some pics up tomorrow...I got the second on tonight...They are nice...Tips fit well for my GTCS rear...Little bit more than stock as every said...I didn't listen to any youtube, ect sound clips so I can't compare from online sound clip to actual sound, sorry...I just knew I wanted a tad more than stock and absolutely no drone...from reading about the stingers I chose GTAs...now, looking back at that decision, I made the right one for me...Plus, I'm thinking the KB 2.6l will give it a slight boost...
Appreciate it everyone! Probably in October sometime I'm going to look at installing/buying these. I don't want ANY DRONE and just alittle louder then stock....highline can you confirm no drone on these?
I appreciate any and all pics that can be posted. I'm looking to do this myself, and I am excited for this! Besides that ratcheting 13mm, no other specific parts? Any tips on taking off old mufflers/putting new ones on?
Awesome, thanks for the tips! Yea I can fit under without lifting the car so looks like I will try that. However, please post pics when ya can. Just trying to get this organized etc before I order them. When you get on them, how does it sound?
Also - thanks for the tip, will look in the for sale section. Any other tips/problems you ran into when installing these, or are they pretty straight foward - replace stock with these. No modifications right?
