o6 GT side pipes
http://www.sherrodmustangs.com/musta...s-features.php
http://www.monocerosmustang.com/stor...0508-p-13.html
http://www.blowbyracing.com/kken-lnr-side-skirt.html
Those are the others I can think of off the top of my head. I have the Cervini kit and love it. I personally think it's the best one out.
The one above is a Ronaele by BBR (Blow By Racing) and the next one below is Cervinis- take into consideration the wind speed below....the Cervini's ones do that too....here you go....anybody remember emay's black stang? Skip to 1:09 for the smoke show or 1:40's for the side exhaust blowing the burnt rubber and smoke away for the car....just sweet!
http://www.youtube.com/watch?v=IM79p...eature=related
Yes- I am a proud pic *****!
Though this pic is not flattering for the car it shows the exhaust!
Are there special considerations when doing something such as the side exhaust by any of the above companies? Yes- as you have to take into consideration the angle at which you exit or enter a driveway to a plaza or any type of speed bump, or your own personal driveway.....drive slow and know the environment that your driving thru. Hope for the best. I can create more lift with taller tires and plan on doing that just so I can lower the back about 1.25 inches effectively removing the rake from the car and the exhaust will sit IMO better when at shows etc.
Never buy 30 series tires all around.....even on 20" rims they are just under 27 inches....so my 3.55 gear is now closer to say a 3.73. I do love the handling they do provide and they stick when warmed up a bit!
You can build your own, I did used 3" pipe and pressed it down to 1 1/2 so it was oval. I copied BBR style. I only lost 1/2" of clearance. I only rubbed it once and I have eibach pro springs. And NO I did not lose any flow with the pipes pressed.
I have the sherrod mustang with the side exits. I love it and so does everyone else who looks my way. I scraped one time but it was my fault, it aint as bad as people make it seem unless you lower your car. I love them, but i noticed that kits like the cervinis and sherrods are thousands of dollars.
trashxtrash
09-20-2015 10:49 PM
