So there I was...
So there I was...
Just checking out some of the new mustangs in Houston. I was at Lone Star Ford and I saw a 2010 Mustang GT-R in the showroom. Couldn't see much else but the badge and it had tape stripes similar to the super snake. This car was kona blue with white stripe. I can't find anything published online about this. Is this supposed to be the "cammer" engine mustang?
lol no!
that dealer does that to so many mustangs in there.
they put rims, stripes, and the gt-r badge...... it disappoints me....
and they do the same with their "mach-1"
my friend in school saw their "mach-1" and here is the way the conversation goes....
"hey have you seen the mach 1 mustang your year"
umm no they didnt make any.....
"yea man they have em i sawz it at the dealer"
ummm naw man they're not mach 1's they just make em look like one its added stuff from the dealer.....
"naw man!! it had the little thing sticking out the hood and it said mach 1 and its faster...
im sure its not faster.... but ok whatever.....
That's what I was wondering. Thought it was odd to not be able to find anything online about that. The badge did look like the old Nissan emblems but its still easy to be fooled. The rims looked nice at least.
Found this info on Ford's website
MUSTANG GT-R CONCEPT TECHNICAL SPECIFICATIONSMustang Returns To Road-Racing, 5.0-Liter Roots With Mustang GT-R Concept
Mustang Racing History Body
Lightweight RPS body panels with carbon fiber hood, aero devices, instrument panel, interior door panels and floor heal pads
Engine – Ford Racing 5.0L "Cammer" V8
Configuration
V-8, aluminum block, aluminum four-valve cylinder heads, forged aluminum pistons
Bore x Stroke
94 mm bore x 90.0 mm stroke
Displacement
5.0 liters (302 cu in/4995 cc)
Compression ratio
11.0:1
Horsepower
440 @ 7000 rpm
Torque
400 lb-ft @ 5500 rpm
Redline
7,000 rpm
Valvetrain
Double overhead camshafts, four valves per cylinder
Intake valves
Two per cylinder, 38 mm
Exhaust valves
Two per cylinder, 32 mm
Throttle body
Twin 57 mm
Drivetrain
Transmission
Ford Racing/Tremec T-56 6-speed
Rear axle
Winters/Ford 9-inch design
Gear ratios
1st
2nd
3rd
4th
5th
6th
Final drive
2.97
2.07
1.43
1.00
.80
.62
4.56:1
Differential
Winter's race-spec rear differential
Clutch
Ford Racing "Cobra R" heavy-duty clutch/flywheel assembly
Driveshaft
Metal matrix composite aluminum custom driveshaft
Exhaust
Complete stainless steel race exhaust with Tri-Y design headers, crossover and side exit tips
Chassis and Suspension
Chassis
Fully reinforced fabrication
Suspension
Original production geometry with lightweight chrome-moly tube (aircraft quality) construction
Front
Reverse-L independent rigid strut tower brace with lightweight chrome-moly K-member and race-spec anti-sway bar with 1.25-inch box section
Rear
Three-link, solid axle with dynamic, fully adjustable shocks with remote reservoirs and coil-over springs, race-spec 1.25-inch panhard rod, and race-spec anti-sway bar
Brakes
Front
Brembo Racing 6-piston calipers and 14.3-inch rotors, 1.25-inch thickness
Rear
Brembo Racing 4-piston calipers and 13-inch rotors, 1.25-inch thickness
Wheels & Tires
Front
Pirelli P275/35/20 racing slicks
20 x 10-inch, 5-spoke billet aluminum wheels
Rear
Pirelli P315/30/20 racing slicks
20 x 11-inch, 5-spoke billet aluminum wheels
Configuration
Bore x Stroke
Displacement
Compression ratio
11.0:1
Horsepower
440 @ 7000 rpm
Torque
Redline
7,000 rpm
Valvetrain
Intake valves
Exhaust valves
Throttle body
Twin 57 mm
Drivetrain
Transmission
Rear axle
Gear ratios
1st
2nd
3rd
4th
5th
6th
Final drive
2.97
2.07
1.43
1.00
.80
.62
4.56:1
Differential
Clutch
Driveshaft
Exhaust
Chassis
Suspension
Front
Rear
Brakes
Front
Rear
Wheels & Tires
Front
Rear
I saw a 2010 GT in grabber blue done up like a Mach with a functional shaker, tinted windows and 20" wheels by a dealer here in Vegas and it looked damn good. It had louvers on the rear window too. I like when dealers do the cars right, but GT-R badge doesn't seem right.
