HOW is your Air Conditionar?
#41
RE: HOW is your Air Conditionar?
The Ultrastart site says " If your vehicle has a manual transmission you can order the 3561M-XR for safe Manual Transmission Operation."
I did not find one of these on greedbay, but they did have an ultrastart 1256m remote start /keyless entry for manual transmissions.
http://cgi.ebay.com/ws/eBayISAPI.dll...sPageName=WD1V
I usually use Autopage starters/ alarms they have 2 way remotes also, but the Ultrastart claim to have more range.
This is what I used on my wifes truck, Takes about half a day to install right, solder all connections etc...I have installed several of these for $300.
Even tells you inside temp remotely.
http://cgi.ebay.com/ws/eBayISAPI.dll...sPageName=WDVW
They work great on auto trans. If you could somehow rig up a neutral switch these would work on manuals too.
TorchRedBeauty,
How did they bypass the transponder key?
StangGuy formerly mrbmp
TorchRedBeauty,
#42
Back on the A/C issue, I've got a black/ black vert and here in north central Texas it's been near 100 every day for quite some time. My car sits in a garage at work and home, so keep in mind it doesn't bake in the sun all day. I almost never take it off of the lowest setting, but I do keep it on Max A/C just to help keep out allergens. I've had to park it in the sun a few times at job sites, after that I do have to put it on the highest setting to cool things off. But usually I lower it after 5 minutes of driving. I keep the passenger vents closed unless someone is in the car with me. The A/C system seems as good as any other car I've had. My boss's black bimmer has the worst A/C of any car I've driven in though! I told him a 3 pack a day smoker with lung cancer could blow harder than the air coming out of his vents
daltron
04-28-2016 08:10 PM
