Last edit by: IB Advertising
Browse all: General Overview
- Ford Mustang Gt 1996 to 2004: Common Problems
Important information to help you understand your Ford Mustang.
What kind of Problems are you having with your 2010?
#241
I just picked my car up this weekend, I have noticed not only with Sync, but most all voice activation software doesn't do well with southern accents. Not sure why. I have also found myself wondering with all the cool stuff Sync can do, why can you guys not make the system interface with some sort of home link style controller for the garage door, then i can just hit the button and say garage open. i hate that damn remote on the visor.
https://mustangforums.com/forum/2010...tallation.html
#242
Okay, for you dealership defenders, listen to this:
I have Ford Racing Performance Parts 4.10 gears in my car, professionally installed.
The car is missing under light throttle when cold (we're talking only the first 30 seconds after the cold startup). Note, that's light throttle, letting the RPMs rise slowly. This happens with the stock tune and with a performance tune.
So, I installed the original stock tune (so the speedo is now off) and took it to the dealership. They just called and claim that the gears make the car rev up so fast that they are confusing the computer. They state it cannot be fixed unless I put the stock gears back in.
Do you believe this crap?
#243
#244
I just got back from the dealer, and they did update the calibration on the PCM -- it might have fixed it, but I won't know for sure until tomorrow morning. Much more to that story, but I will put it in another thread (as you suggested).
But, as it relates to the problems with 2010s and whether the dealers can fix them: The mechanic was a descent guy, but even he admitted to swinging in the dark on this one. He seemed competent enough (and not deserving the "grease monkey" label I used in an earlier post), but the bottom line was the problem was beyond his fix.
Now, when I called Tillman Speed, they had quite the grip on things and deduced the cold air/fuel tables were off. If the computer recal that the dealer did fixes it, then we know that was correct. But, again, I'll give details about that in another post.
#245
UPDATE: I just drove the car "cold," and the problem is still there. I'm very frustrated.
I have a Tillman tuner coming, so I guess I'll see if it helps. I am not optimistic, though. I'm convinced there is a "mechanical" issue somewhere that needs addressed.
#246
Hello! I need some tech advise... just bought a 2010 mustang, interior lights go out when headlights are on.... can use the dimmer but doesnt get bright enough. Dealer says its suppose to be that way? they started comming on then off..
#248
[QUOTE=v6motorheadftop;6877043]I'm getting squeaking noises on the startup(sounds like a pulley is causing the belt to screech)
I noticed this on mine too, however very infrequent. Have noticed a constant whistle coming from the area of the alternator and tensioner...but once again not all the time and of course not at the dealer. They want me to leave it there the whole day running until the tech hears it. I think I will wait until it happens every time, so not to waste gas at the dealership.
#250
My 2010 mustang problems so far
Car shut off while driving on the highway 3 yrs ago. Coasted to safety and 3 days later I found a tiny piece of leaf in the MAF sensor. I cleaned it with maf cleaner, car started again but runs rough since. Other issues & repairs since:
*Purge solenoid valve (2017)
*EVAP canister (2017)
*EGR Valve (2017)
2- batteries (2016 & 2019)
Brake pads (2019)
Rotators (2019)
*O2 sensors (2019)
Air filter (2018)
Thermostat & housing (replaced twice now since late 2017 & 2019, first one the gasket at the base melted)
Wiper blades
Tires
Drive belt (2019)
Idler pulley (2019)
•A/C flushed, dye tested & recharged (2017, they found no issues yet a/c would blow hot and then cold sometimes, now only blows hot and a/c not turning) note: immediately after changing out the drive belt & idler pulley the a/c blew ice cold for 10 mins, now only blows hot and clutch doesn’t engage after driving it mins afterwards)
•fuses #25, relay for blower motor #51 (2018)
•clicking noise in dash during start up
•Check fuel fill inlet light on & off the past few months now
*all have been replaced but still throwing check engine light codes
*EGR Valve (2017)
Brake pads (2019)
Rotators (2019)
*O2 sensors (2019)
Air filter (2018)
Wiper blades
Tires
Drive belt (2019)
Idler pulley (2019)
Driver72
01-30-2012 05:13 PM
disturbed!
07-08-2009 07:54 PM
