07 GT 5.4 sawp $$$$
07 GT 5.4 sawp $$$$
I have a chance of picking up an engine from a 07 GT500 5.4 S/C complete with the harness. My 07 GT is stock with an automatic transmission and stock gears, this 5.4 is available for about 3500bucks and I can make payments on it. My question is it a drop in with minor mod’s or does it require too much time and money to make the swap. Any advice will be appreciated.
Thanks,
Thanks,
Crossmember are different as well.
You'll need the GT500 one... and all the little parts that it's impossible to know you will need, until you get to that point.
PLstang, is a member that has done the conversion with an automatic tranny...
He doesn't logg in anymore, but he'd be the guy to contact.
If the search feature is efficient enough, you could find the thread he posted a while back.
If you were to do this, don't forget the money needed also, to mod the Shelby engine.
You wouldn't want to leave it stock, would you?
your tranny will bolt up to the 5.4 luckily
not sure how long it would last...biggest issue would be getting the GT500 PCM to command the tranny
I personally would grab that motor and then flip it for $$$$. Then buy a blower. When done, that swap would be nothing but fun, but the headache to get your there.
Gary Ugarek
63
12-11-2015 02:01 PM
