Do you get your car chassis/suspension greased?
Nope, no grease fittings and dont let the stealership
charge you for undercarrage/suspension grease service...
The front bushings are hydro-rubber and will need replacing
soon enough.
The rears are also rubber OEM...
soon enough.
Everytime I brake my car feels like it turns (the wheel turns a little) and also over bumps. There is nothing wrong with the pads or anything and its all aligned. Do you think the bushings are worn? Its an 05 with 45k miles on it.
I was wondering really how long these bushings last. I was thinking of going poly bushings.
Definitely a worn/warped rotor or binding caliper unless you've smacked a curb really hard. I had a similar problem after hitting a curb hard and bent the tie rod. There's nothing else that could cause that problem. Brake issues or tie-rod issues. Or you need a bumpsteer kit, basically tie rod spacers.
Eibach Pro Kit
Unless you have a properly installed bump steer kit, you
might be having trouble with bumpsteer.....
