windex vs invisible glass vs winshield washer fluid
Hello,
Ok, so I am sure a lot of people have the same problem of having spots on their windows. I have done some searching in the forum and found a lot of talk about the different kinds of cleaners.
I hear a lot of votes for both Windex and invisible glass, however, I find that when I go to the gas station and clean my windows with the free window washer fluid (WWF) in those trashcan side-buckets, my window are really clean. Does anyone have an opinion on this? Whould it be bad to buy some WWF, spray it into a MF towel and clean the windows with that, inside and out? I haven't tried it yet myself, it just came to me.
Just so you know, I was my car in the shade, with water and car cleaning soap. Then rinse after washing and dry with a MF towel. I still gets spots on my windows and side mirrors.
Thanks for your input, as always.
Just make sure everything is cool when you wash the car. The spots can be taken off with steel wool and windex. Make sure you use the super fine steel wool (I think its the 0000 type).
You might just have some left over from before, it happens. Also I use simplegreen usually the clean my windows (very high dilution, so its mostly water) and it cleans them right up with no streaks.
Spotting on our windows is a chronic issue. I don't know if it's something Ford coats their glass with or what but I've never owned a car that was this much of a pain to get spots off the glass.
My best luck (after trying about 1/2 dozen products including vinegar and newspaper) came with the solvent that I had bought for cleaning glass and body components prior to using the 3M double sided tape.
I use stoner's invisible glass on the inside and rain-x on the outside. If you use a microfiber with stoner's, it will not leave spots behind. Just dont soak the cloth so much and go over it with a dry microfiber after using the wet one.
If you have waterspots on the outside of your glass from hard water, then those are a pain to get off. The thing I have found which works best is a car polish. You can use cleaner wax or like meguires scratch-x or any other car polish you have. They will take water spots off the easiest. I have had no luck with claybars or using vinegar. The polish will take it off quickly and easily and leave the glass nice and clear.
Do people not know about steel wool? I know a lot of people are scared it will scratch but if you use 0000 type it doesnt.
I used to use it to get overspray off windows at the bodyshop I detailed at.
Edit: Sorry thought you were asking what to use... nevermind. Glad steel wool worked out for you I would have hesitated
I can try the steel wool.
Does anyone have an opinion about the Windshield washer fluid?
