Hood pins and latch question
Not absolutely necessary but highly advisable.
If you're concerned about inadvertantly popping the latch release before pulling the pins, you may want to consider these -
http://www.shelbyperformanceparts.co...pin%20kit.aspx
You won't cause any damage to your hood if you forget to pull the pins before the latch (a mistake I've made several times :/).
Well besides it being an attempt to be anti-engine-part-theft
or a anti-battery tampering deterent, the OEM hood latch is
also a good center hood retention device, so no, dont remove it.
The next owner will thank you...
Hey Red Beast, I have a question about your hood pins? What brand are they and where did you get them from. Secondly, how were the pins attached under your hood. I'm getting the trufiber gts-4 hood, and want to add hood pins, and i want to get pins that I will be able to use with the hood.
The same question goes to Cutterwolf, if he has any inputs.
Thanks guys.
Thanks guys.
