Gauge Cluster Swap reall Worth it?
Old 08-26-2009, 12:08 AM
Orion_240
Orion_240's Avatar
Aren't there better upgrades you could be making to your GT than spending that kind of money just to get a different gauge cluster?
You could get full CAI, tuner and more for the same $$$.
Not to mention the possible warranty effect this could have
Orion_240 is offline
Old 08-26-2009, 08:24 PM
GrayGhost01GT
GrayGhost01GT's Avatar
i talked to a Ford Rep and he said it wouldent affect the warrenty because it would be installed by Ford Rep, but trying to get the dealer to say it wouldent would be a different story he said they will tip toe around everything and try to use any excuse to not fix something on your car if they know something has been changed! But I think I might just wait and do leather seats and Exhaust! Already got my tuner and love it I actually was very suprised I chirped tires all the way through 3rd gear on my auto tranny the other night! Love that plasterd Smile!!!!
GrayGhost01GT is offline
Old 03-10-2018, 05:02 PM
GT2fast
GT2fast's Avatar
Default Better option.
You can get the cluster on eBay for less than $200
GT2fast is offline
Old 03-11-2018, 10:12 AM
Dino Dino Bambino
Dino Dino Bambino's Avatar
Nine years on, he may have sold his Stang long ago.
Dino Dino Bambino is offline
Old 03-11-2018, 01:55 PM
08'MustangDude
Yeah, nine years ago...
Less than that now. I just found one for $58.00 with 68000 miles on it's clock...
I also have the harness for the menu/info/reset buttons. Those cost more than
the cluster, and you need it for the upgraded cluster.
08'MustangDude is offline
Old 03-02-2019, 06:20 AM
vdanielsan
Has someone done successfully the cluster gauge swap? I've got a 2007 Mustang Base Convertible 4.0L, with basic cluster, and I would like to install the premium one, with the 4 little clocks and display for Onboard Computer. I've already checked I've got the cables behind the 3 buttons cover, on the central console, but I think I've read somewhere that you can just swap the exact P/N cluster. Is there kind of ECU that can be reprogrammed or changed?
vdanielsan is offline
Old 03-02-2019, 06:36 AM
Dino Dino Bambino
I did the six-gauge cluster swap into my GT Deluxe a long time ago and it was as easy as pie. All you need is a 7mm socket with ratchet and swivel extension to remove the four retaining bolts. Just move the steering wheel down to its lowest setting and gently pull away the gauge bezel to gain access.
It literally takes no more than 20 minutes to remove one cluster and install the other. The info/setup/reset button panel takes only seconds to install, and the wiring pigtail for it is already there behind the dummy panel.
You'll need to have the new cluster reprogrammed with the mileage from the old one by a Ford stealership unless they're both very close.
Old 03-02-2019, 05:57 PM
vdanielsan
Great, thanks! I'll give a try!
jwog666
01-07-2018 07:16 AM
5.0muscle
01-11-2016 01:17 PM
andrew1969
16
01-08-2016 02:48 PM
treesloth
09-28-2015 07:03 AM
nmra1965
Other Professional Racing
09-26-2015 10:46 AM
Quick Reply: Gauge Cluster Swap reall Worth it?
Featured Sponsors
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
